Multi quoting
Discussion in 'The Pub' started by looktall, Dec 30, 2016.
  1. looktall
    looktall New Member
    You can use the +quote button to select multiple comments as is possible on the current forums.
    But there's another way.
    If you click on the reply button it will quote the comment in the quick reply box.
    If you then decide you want to add another quote you can just scroll up and click the reply button on that comment and it will add it into the quick reply box in addition to the first quote.
  2. Agg
    Agg Staff Member
    Neato. You can also drag text in messages and use the popup thingy, as I did above.
  3. encode
    encode New Member
    You can also click reply multiple times for added effect.
